Which will look better
I use the akasa pro, and it would fit well with the rest of the blue LEDs on the fornt, that being said Ive replaced all my fans with noctuas so the blue glow is actually irritating, lol
I would go for the zalman its a good controller the only down side, as is said in all the reviews and from my own experience is it has to be looked at straight on or you cant read what its saying. For looks then definately the zalman:cool:
They loook very nice never had one myself! But now I am thinking about one!!
How do they actually work? what do you plug them into??
as above a molex powers the unit and you have several leads for your fans, one for your cpu fan if you so desire so it can still be controlled by your m/b. On top of that there is a device for monitoring your power consumption which is neat, and four temp monitors which is great if thats what your into:D
