Which ?Wireless USB 2.0 Network Adapter
CSA
CSA
20 Apr 2006
Lancashire
Hi , im moving house soon and would like to connect my childrens pcs to my netgear router using wireless adaptors rather than ethernet cabling them like they are now (just saves hassle) which adaptors should i be looking at for good performance that dont cost the earth ?
mainly for file transfers,internet inc youtube and maybe the odd bit off online gaming, are these things any good for online gaming ?
Best to keep the same vendor for compatability of features, as for gaming the difference isn't massive, there's a few ms more latency depending on the signal quality and level of security but nothing that will really make much difference.
Anything in the price range of £15-20 that supports 802.11g should be fine. If it supports external aerials even better (can replace them to get better signal if it becomes necessary)
