My case allows for a 200mm fan the be placed at the top, but the fittings also allow for two 120mm fans in its place. I was just wondering if any of you guys knew which method would be better noise-wise and effectiveness-wise.
Worth pointing out also is the fact that I can't seem to find 200mm fans in stock on a site that I trust or even in local PC stores :/ I can find 120mm fans no problem, so if the difference isn't huge then I might as well go for the two smaller fans...
