Which would be quieter?
22 Jul 2006
Right, i am currently cooling my conroe with a big typhoon, i was just wondering if i replaced the fan that comes standard with the typhoon with an asaka amber, would it make much difference in noise?
Thanks
Probably, as Thermaltakes noise figures are usually way off the mark. Don't forget though that you might also lose airflow as well and that means higher temps.
