Which Wraith cooler?
Rup
Rup
23 Aug 2017
Hi All,
I recently bought a Ryzen 3600 from here. Works well & happy with it.
But seeing reviews saying that it's cooler, Wraith Stealth is rubbish.
Would it be worth upgrading to a Wraith prism which is £20 here?
Happy with a mild overclock.
I would start using the PC first. If you're then not happy with the performance of noise levels, consider replacing.
I wouldn't pay to upgrade to another stock cooler through as it will only be one step better. For not much more than £20 you can get some very capable coolers.
Edit: if you're overclocking, certainly get an aftermarket cooler.
Ok thanks mate. Quite happy with stock cooler but £20 for what reviews say is much better cooler and RGB, is tempting.
Thanks for recommendation mate, that one's OOS now. Have gone for Prism now, only £20 so little downside & it looks nice too.
Finally installed the Prism. Very happy with it, runs cool & quiet and RGB looks lovely.
And some people spend £50 on Nochtua baby puke coolers :)
