Do you use mid-end/high end headphones/speakers? If your answer is yes, then I recommend the Elite Pro. Otherwise, it really depends if you need all the connectors.. I don't so my second choice would've been the Xtreme Music. The Elite Pro come with better DAC/Op-amp (a la EMU 1212), so it'll allow you to push better gear further. IMHO, the Fatal1ty is the one questionable in terms of value.
