Hi guys, anyone know what Compression Fitting i need to connect 2 Ati HD5870 PCS+ with EK-FC5870 V2 Nickel Plexi water blocks? the only 1 i found was the Feser G1/4" Thread SLI and XFire Fittings for 1,2 and 3 Slot, is that the only one i could get? im using Bitspower 7\16" ID - 5\8" OD Compression Fittings atm, so hoping if i can get the X-Fire fitting from Bitspower as well if possible.
Best Regards..
Tony
Best Regards..
Tony
