Which X1900 XT?
22 Oct 2005
Thailand
I brought this up in another topic in this forum, but it was OT so I made a new one.
I am thinking I will buy this X1900XT:
PowerColor ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-060-PC)
It is in the one week special, and is the cheapest X1900 XT available here. I want to know if I should opt for an alternative one though. Please share your opinions about this.
Also, are the XT-X versions more overclockable?
Yeah the XTX's are more overclockable, as they have better Ram, and are cherry picked, but the XT is still a good clocker, it should go to XTX speeds, and possibly higher.
It doesn't matter which XT you get as they are all the same, only differences are the pics on the coolers, and what software you get, so just go for the cheapest. :)
Thx for your help! :)
I assume the same logic of grabbing the cheapest one available applies to the X1900 XT-X as well yes?
my PC x1900xt is running at 690core ram ive not touch to much as the heatsink dumping to much heat on to them from the core , waiting till my V900 to oc the ram more
