which xonar?
Technically, I'd say the PCI version is better, as it doesn't need a Floppy Disk power connector.
However, I own the PCI-E version and its all fine except I don't really like the small connector it uses to slot into the motherboard (a bit loose).
The PCI-E version was supposed to be better for Vista (that's what Asus was claiming a while ago).
Tbh, your mate should just buy the cheaper PCI card.
why not save more dosh and get the DX?
i doubt anyone without a seriously high-end setup could hear any perceived differences between it and the D2/D2X ....reviews suggest the same.
Doesn't the d2x support EAX 5 and has LEDs at the back, handy to plug things in without looking at the card.
