which xt1950 pro card?
12 Dec 2006
hi
which card should i go for??
fx-57
2Gb of ram
current grahpics 6600gt
running 19" 1240 x 1024
PowerColor ATI Radeon X1950 Pro Extreme SILENT Heatpipe 512MB GDDR3 VIVO HDTV/Dual DVI (PCI-Express)
or
Connect3D ATI Radeon X1950 XT 256MB GDDR3 HDTV/Dual DVI (PCI-Express)
It will rape anything you use at that resolution.
The pro will just ruff it up a bit
Those 2 screens will be a total of 2621440 pixels I believe, People can use 1950XTs to games at resolutions of 2048x1536, which would be a total of
3145728 pixels. So my detective work says no problem at all!
