Which Z170 Motherboard?
19 Jul 2006
Leicester
Cheers stulid. I do have the CPU already, so would you go with the 170XP-SLI over the 170X-UD3? I'm not going to be overclocking or anything either.
Hmmmmm.
Not sure to be honest, check the number of usb, sata etc and pick one.
They are both 3yr warranty.
I've gone for the UD3. They're pretty much the same to be honest and the UD3 was the one I was going to go for originally. Thanks for the help.
