Whinging noise....
27 Aug 2005
Hi there
Does anyone know which component/fan is the LAST thing that switches off when turning the pc off?
Reason I ask is I'm getting a whinging sound shortly after the pc has powered up and it it driving me crazy! Its a new build but never had it for the first couple of weeks. I have tried looking but as they are very close together I can't tell where is causing it.
However, when I turn off the pc its the LAST thing that powers off if that helps.
Thanks
It could be your GPU, as the power is cut the buzzer warns of low power very quickly, Some people had this problem last year with there GTX's I think!
Rob
power supply?
whats the spec.?
OcUK GeForce 8800 GT 512MB GDDR3 HDTV/DVI (PCI-Express) -
Intel Core 2 Quad Pro Q6600 2.40GHz Guaranteed to run at 3.00GHZ (1333FSB)
Asus P5K Pro Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Corsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
Samsung 750GB Hard drive
Rob
After the power is cuts its slowly whines down hence why I ask the last component to turn itself off etc.
