Whirlpool AKP511 oven - can't figure it out
10 Jul 2006
Trying to cook dinner for the first time in my flat but I can't figure out the damn oven.
Is anybody able to find me the instructions online, have spent the last 30 minutes trying to find them
...or able to tell me how I use the damn thing!
How it works?
I presume just push the buttons in and they will pop out, then twist them.
If it's never been ran, then it will need to be activated somehow, usually pressing buttons in a sequence activates it.
Do the controls look anything like this?
Function knob to "Oven"
Temp to 200°C If it doesn't get hot after ten mins it's broken.
Red light should come on if you've twiddled the knobs correctly, then it should extinguish when it reaches 200°C
Well I had turned the function button to what I thought was oven with fan and turned it to 200. The light went on, and went off again a short while after, no way it was 200*C though.
He ended up ordering in...
Yup...haha
Some ovens I have used need you to set the temp etc (lights would come on), then press one of the small buttons on the left to get it to heat it up.
might not be but worth a try.
