Whistling Noise On Certain Games
5 Dec 2008
London
This problem only happens on certain games and only during the main menus but I have just got FIFA 15 and it does it on that. During the first few menu screens, a very loud and annoying whistling noise is heard which does go when the game begins.
Intel Core i7-3770k
8gb RAM
AMD Radeon HD 7950
I don't think that my system is to blame as after a few seconds, there is no longer a problem. Other games where it does this include Crysis and Just Cause 2.
I have quite an old set of Logitech 2.1 speakers. Would getting new speakers fix it or do you think there is another reason this happens?
Thanks.
This is known as coil whine and is a common occurrence for many graphics cards and sometimes even other components such as the power supply.
This^^
I have heard that setting a max fps limit dulls the noise/fixes it.
It's just luck of the draw weather you get a noisy gpu or not.
If you only hear it during main menus it is due to the stupid high fps you are getting in those scenarios.
Use something like msi afterburner to limit your fps to just above your monitor's refresh rate.
Yeah first thing I always check for when buying and tech is good quality caps
Indeed, something like this should suffice
