Whistling sound from new 8800gtx
2 Nov 2007
Hiya
Just bought a new 8800gtx. Installed and tested succesfully. Only problem is that when playing any game i get a high pitched whistling sound from the card. Is this serious? I googled it but only got results about whistling PSU's. Any ideas what it could be? Should i rma the card?
Thanks.
in windows no. only when i load up a game. i've tried with portal and ep2 so far. the whistling goes away when it goes to a loading screen which makes me think it's something to do with when the card has to use 3d.
Sounds like a capacitor or coil coming into audiable range. Either you can RMA or try increasing voltage very slightly on the board to get it out of audiable range.
Mines only beeps when my PC is shut down when the power is cut off, but it's very faint tho, but this is apparently normal.
I've never had that problem running games tho, but i've heard that it's very common.
Same my BFG GTX OC always whistles while it works :)
I only noticed it when I removed the ****** fan and slapped a waterblock on the mutha!
Works a treat though :D
