After consulting the OCUK forum to get a little feedback on components for a build, I finally settled on this:
YOUR BASKET
1 x EVGA GeForce GTX 780Ti Dual Classified ACX 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2888-KR)
1 x Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74930K)
1 x Asus Rampage IV Extreme Black Edition Intel X79 (Socket 2011) DDR3 Motherboard
1 x BenQ XL2720Z 27" TRUE 144Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red
1 x Kingston HyperX Beast 16GB (2x8GB) PC3-19200C11 2400MHz Quad Channel Kit (KHX24C11T3K4/32X)
1 x Samsung 500GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE500BW) **£18 CASHBACK
1 x SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - White
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Arctic White (CC-9011048-WW)
1 x Corsair Vengeance K70 Mechanical Gaming Keyboard – Red Switch (CH-9000050-UK)
1 x Microsoft Windows 8.1 Pro 64-Bit DVD - OEM (FQC-06949)
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW )
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW)
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD
2 x Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack (CO-9050002-WW)
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
I didn't take many pictures during the build but I'll post what I have.
I changed all the case fans for Corsair Quiet edition with a white ring. (Packaging comes with white, blue & red)
A couple of components
MB & CPU fitted
Test fit, wires everywhere but it posted first time and I then cleaned it up a bit before installing everything.
Thats it for now, I've just been enjoying it so far.
Future plans:
LG Flatron superwide monitor
SLi 780Ti (not sure about this yet)
Watercooling (maybe next year)
Better case lights
Remove Sound Card (Never gets used)
Thanks for looking, and to those who helped me with the spec, thanks.
YOUR BASKET
MB & CPU fitted
Future plans:
Better case lights
They really are good and cheap though! Make sure you get a 300LED / 5 metre strip instead of 150LED / 5 metre, not the one's the OP in the thread I posted but double the amount of LEDs
