I'm currently in the middle of getting some parts in for a build I am doing for the wife and am getting to the point where most of it should start arriving over the next month or so, so far I have the following:
Corsair Carbide 275R case in white
Asrock b450 motherboard
AMD Ryzen 2700x
16GB (2x8) Glowey 3200mhz rbg memory (Seriously cheap from a friend of mine in China) - If it even works for £35 delivered ill be amazed.
Already got:
PSU: Either Seasonic 750 prime platinum or Kolink continnum 850 platinum.
GPU: Either rx550 2gb, rx550 (baffin) 4gb flashed to rx560 ish, or vega56/64. Undecided on how much gpu power she will need but will likely drop one of these in.
Will likely give her my samsung 34 120hz UW and upgrade mine.
So with the above in mind and going for a white/purple or white/pink build and thought that I might hard line loop it as well using as much white and rgb as I can. I want to start with just a cpu loop and go from there and want as much corsair rather than other vendors (I have a corsair case, aio etc in my build black/blue and would like hers to be a baby version of mine albeit with inferior internals) but its a minefield and every time I put together a basket I end up lost. WC masters of ocuk.. please help me!!
AMD Ryzen 2700x
Already got:
