White backplate for 1080?
31 Dec 2006
I don't think anyone makes these do they? The only option I've seen is a US company called V1 Tech that do custom acrylic ones. I thought Bitspower used to do one, but doesn't seem they do any longer, if they ever did.
Coldzero can sort you out,I've bought stuff from him for a corsair case I had a while back.
There is a few options.
Buy a custom made backplate.
Buy a backplate and paint it white. I plastidip painted an EK gold 780ti backplate then added a layer of fast dry project enamel for a glossy finish.
Make your own backplate. I did this for my soundcard, bought a custom size piece of ally for about £5, washers and screws cost about £2. Wasn't very challenging but very satisfying to have something you made in your build. I don't even use the soundcard anymore but keep it in the system cause it looks good.
Plastidip your current backplate. In the event you need to send it back to EVGA then you can just peel the plastidip off and it'll look good as new.
