White bladed radiator fans
10 Apr 2015
Hungerford, UK, Earth
One of my aio fans has failed. So I'm looking to replace all 3. What's the best 120 mm pwm fan preferably with white blades to use on my overoclocked 8700k. Doesn't need to silent prefer white blades as using halos frames
Can strongly recommend the Arctic P12 PWM if you get the PST version you can daisy chain the three fans so you can cut down on the clutter. If you check around you can find them with white frames and either transparent or white blades. You really won't find better for the money, I've replaced all my fans with P14s and P12s and can't get over how much air they move at really low noise levels.
Not 120mm fans but this may be useful.
thanks, i will go for 3 of the white blade/frame ones, as the frames are hidden by the halos frames anyway
