white case's ? any about....
19 Feb 2008
Home
hi all,been looking at some of the case's being modded lately and has inspired me to do mine this summer.
i have got a antec p190 which is as you know....black and silver inside.
i will be building a new desk soon which will be painted white to go with the living room when it has been decorated.
a white desk and black case underneath wont match so i was thinking of painting/spraying it white to blend in a bit better.
has anyone done a pure white case before ?
will post pictures up of the before and after shots of my current desk and pc and new desk and hopefully new white case.
i remember watching both of those been built and are trully stunning piece's of work.
mine's not going to be that flash but just painted white.
I think that white, when done well can look very nice. Look forward to seeing how yours turns out.
If you actually want to buy a "new" case then the p150 is pretty good, however you will probably have to buy used.
It also has a rubbish plastic set of optical bay covers which break easily (mine broke twice and in fact my P150 is sitting in the loft with one missing at the moment, after being replaced by a Lian Li B25, which although better looking isn't quite as good as the P150 I think).
I actually own three white cases - Akasa Zen. They come like that new, looks pretty good actually, though they are budget/mid-range orientated. Trying to get rid of a couple now actually, no boxes though unfortunately.
i dont want to get rid of my p190 as i like the door on the front for a clean look.
just fancied a change and painting it white will be just what my case need's.:D:D
