** WHITE DDR4 MEMORY FROM CRUCIAL & GEIL!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Skylake has really caused DDR4 to come down to near DDR3 prices and were now seeing some pretty incredible designs and some very fast kits.
Check some of these out:
GeIL White Dragon "SUPER Low-Latency" 16GB (2x8GB) DDR4 PC4-24000C13 3000MHz Dual Channel Kit - Blue LED (GWW416GB3000C13DC) @ £149.99 inc VAT
DDR4 Dragon RAM Gaming Series, continuing GeIL’s dragon legacy with an all new frost white 10-layer Dragon PCB design mounted with blue LED. Covering speed of up to 3333MHz, the series is available in Dual, Quad and Dual-Quad Channel kits, tested for the latest Intel Z170 & X99 platforms for maximum compatibility and performance. Frequencies above 2800MHz receive PCB-matching frost white IC finish, while lower speeds’ remain in black.
Features:
- 10 Layer PCB for improved OC ability and lower latencies
- Blue LED's
- Oven baked for less than 0.1% failure rates
- DYNA 4-Tested for imp[roved Reliability
- Intel XMP 2.0
- GeIL/OcUK Lifetime Warranty
Specification:
- 3000MHz (PC4-24000)
- CAS Timings: 13-13-13-35
- Voltage: 1.35v
Only £149.99 inc VAT.
ORDER NOW
GeIL White Dragon 8GB (2x4GB) DDR4 PC4-24000C14 3000MHz Dual Channel Kit - Blue LED (GWW48GB3000C14DC) @ £65.99 inc VAT
Features:
- Blue LED's
- Intel XMP 2.0
Specification:
- CAS Timings: 14-16-16-35
- Voltage: 1.35v
Only £65.99 inc VAT.
ORDER NOW
GeIL White Dragon 16GB (2x8GB) DDR4 PC4-24000C14 3000MHz Dual Channel Kit - Blue LED (GWW416GB3000C14DC) @ £119.99 inc VAT
Features:
- Blue LED's
- Intel XMP 2.0
Specification:
- Voltage: 1.35v
Only £119.99 inc VAT.
ORDER NOW
GeIL White Dragon 8GB (2x4GB) DDR4 PC4-25600C15 3200MHz Dual Channel Kit - Blue LED (GWW48GB3200C15DC) @ £68.99 inc VAT
Features:
- Blue LED's
- Intel XMP 2.0
Specification:
- 3200MHz (PC4-25600)
- CAS Timings: 15-17-17-35
- Voltage: 1.35v
Only £68.99 inc VAT.
ORDER NOW
GeIL White Dragon 16GB (2x8GB) DDR4 PC4-25600C15 3200MHz Dual Channel Kit - Blue LED (GWW416GB3200C15DC) @ £129.95 inc VAT
Features:
- Blue LED's
- Intel XMP 2.0
Specification:
- Voltage: 1.35v
Only £129.95 inc VAT.
ORDER NOW
GeIL White Dragon 16GB (4x4GB) DDR4 PC4-25600C15 3200MHz Quad Channel Kit - Blue LED (GWW416GB3200C15QC) @ £129.95 inc VAT
Features:
- Blue LED's
- Intel XMP 2.0
Specification:
- Voltage: 1.35v
ORDER NOW
GeIL White Dragon 32GB (4x8GB) DDR4 PC4-25600C15 3200MHz Quad Channel Kit - Blue LED (GWW432GB3200C15QC) @ £229.99 inc VAT
Features:
- Blue LED's
- Intel XMP 2.0
Specification:
- Voltage: 1.35v
Only £229.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport LT 16GB (2x8GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - Black/Grey (BLS2C8G4D240FSB) @ £99.95 inc VAT
Designed for performance enthusiasts, gamers, and anyone who simply wants to get more out of their system, Crucial® Ballistix® Sport LT DDR4 memory helps you do just that. Give your processor the resources it needs to perform and make your computer faster and more responsive.
Memory is fun when it’s faster, when it’s stylish, and when it helps your system perform at a higher level. Compared to standard Crucial DDR4 memory, that’s exactly what Ballistix Sport is engineered to do. Get faster speeds and run demanding applications with ease. Multitask at will with increased bandwidth. And strike first with better latencies and reduced load times.
Getting more out of your system should be easy— and that’s exactly how we engineered Ballistix Sport memory. Using cutting-edge technology, intuitive module design, Intel® XMP 2.0 profiles and more, we designed Ballistix Sport with the sole intent of creating affordable, easy-to-use performance memory. Installation is a cinch: just plug-and-play, and get ready to win with little to no BIOS configuration.
With a stealth digital camo design and integrated heat spreader, Ballistix Sport LT is designed to be your memory lieutenant. Keep your system cool and collected while mowing down the opposition—whether that’s a challenging spreadsheet or an opponent you’ve just reduced to a bloody pulp.
As a brand of Micron, one of the largest memory manufacturers in the world, Ballistix memory is built to last and delivers a higher level of performance than standard memory. For more than 35 years, we’ve engineered oldschool DDR memory all the way to Ballistix Sport DDR4, which empowers you to seize an affordable performance edge. Backed by a limited lifetime warranty and rigorously tested to some of the most demanding standards in the industry, Ballistix Sport LT DDR4 memory has been thoroughly proven and is ready to make an immediate impact in your system.
Features:
- Speeds start at 2400 MT/s
- Faster speeds and responsiveness than standard Crucial® DDR4 memory
- Ideal for gamers and performance enthusiasts
- Dual / Four channel memory architecture maximizes data rates
- Digital camo heat spreader available in white and gray
- Easy plug-and-play installation
- Intel® XMP 2.0 profiles for easy configuration
- Optimized for the latest Intel Z170 & X99 platforms
- Limited lifetime UK award winning warranty service.
Specification:
- 2400MHz (PC4-19200)
- CAS Timings: 16-16-16
- Voltage: 1.20v
Only £99.95 inc VAT.
ORDER NOW
Crucial Ballistix Sport LT 64GB (4x16GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black/Grey (BLS4C16G4D240FSB) @ £389.99 inc VAT
Features:
Specification:
- Voltage: 1.20v
Only £389.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport LT 8GB (2x4GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - White (BLS2C4G4D240FSC) @ £49.99 inc VAT
Features:
Specification:
- Voltage: 1.20v
Only £49.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport LT 16GB (2x8GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - White (BLS2C8G4D240FSC) @ £99.95 inc VAT
Features:
Specification:
- Voltage: 1.20v
ORDER NOW
Crucial Ballistix Sport LT 32GB (2x16GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - White (BLS2C16G4D240FSC) @ £199.99 inc VAT
Features:
Specification:
- Voltage: 1.20v
Only £199.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport LT 64GB (4x16GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - White (BLS4C16G4D240FSC) @ £389.99 inc VAT
Features:
Specification:
- Voltage: 1.20v
ORDER NOW
This is just a handful, there are many more kits, so check them in our online store to see the whole range:
Crucial Range!https://www.overclockers.co.uk/prod...01&catid=8&sortby=manual_sort&subid=&mfrid=30https://www.overclockers.co.uk/prod...01&catid=8&sortby=manual_sort&subid=&mfrid=30
GeIL Range!
2800MHz & above: White PCB & White IC!
2400/2666MHz: White PCB & Black IC!
Black Dragon was a huge hit on DDR3, I can see this new White Dragon range being a huge hit as well. :)
CAS13 @ 3000MHz, now we're talking! :)
Yes but more impressive is the timings are 13-13-13-35, but I know yields are poor so supply is small.
But good to see it is not something like 13-15-15-35, so should be great kits. :)
Damn, why were these not around a month ago, I've just done a White build. Went for black Corsair Vengeance LPX. Do I change?.....
I bought the White Panram kit as it was the only *x8gb kit available... Yesterday.
Just my luck but these kits aren't quite to my taste... The timings look interesting though.
Up to you, OCD may kick in ;) Got a pic of what it currently looks like?
Well although you can't see the RAM at the moment due to the huge heatsink, I know its there. When I watercool the thing the memory will be on display.
Anyway here's a link to the build and some pics
https://uk.************.com/b/BVzMnQ
Love me some white PCB,Wish more motherboards and graphics cards had white PCBs :(
Those heatsinkless kits would have looked much better without the yellow on though i think.
Nice prices though. :)
