White DDR4 RAM less than £200
29 Dec 2014
The "North"
Hi, I'm planning on building a black and white/clear X99 build but I've come across a slight issue.
I can't find any white DDR4 RAM without it going over my budget.
So does anyone know if/when their will be white DDR4 RAM as I would have thought Kingston would have made their white Fury RAM or Corsairs LPX but I can't seem to find any :confused::confused:
Panram Ninja-V do different white kits inc an 8GB (2x4) that will be in your price bracket.
(Panram PUD42400C154G2NJW 8 GB DDR4 Memory)
Not sure on their OCing ability though, so you'd need to do a bit of research on them.
That's the issue as for a similar price I can get a 16GB kit that is known to OC well :eek::eek:
