white edge around desktop icons?
Open System Properties in Control Panel, choose the Advanced tab, and click Settings in the Performance section. Turn on the Use drop shadows for icon labels on the desktop option, and click Ok.
Windows XP
You can also try MicroAngelo (v5.5 or later), which allows you to change the text color, configure custom icons, and change other aspects of Windows.
Another utility of this type is WindowFX.
Windows 2000
Obtain and install the Transparent utility.
You can also try the "On Display" feature of MicroAngelo for lots of extra features.
Windows 95, 98, Me
Obtain and install the Disappear utility (4 kb). You'll need VB40032.DLL (381 kb) if you don't already have it.
Note: in all versions of Windows, Microsoft provides no way to change the color of the text under desktop icons, which can make it very difficult to read in some circumstances. In Windows XP, the text has a shadow underneath, but this only goes so far. To change the font, open Display Properties in Control Panel, choose the Appearance tab (then click Advanced in Windows XP only), and choose Icon from the Item menu.
nomad said:
weirdness, did the above and its still like it. dont really wanna install anything to do it!
I don't think that method for XP works if you have active desktop content.
