White (ish) pc build - thoughts?
29 Oct 2019
Derbyshire
I have put together a list which I would like OCUk to build for me. I don't know one end of a screwdriver from the other, and if something went wrong I wouldn't have the foggiest how to fix it.
I will be using my old 1080p 60hz monitor, but hope to upgrade to 1440p maybe in a year or so. How does it look?
My basket at Overclockers UK:
Total: £1,371.44 (includes shipping: £14.10)​
Hi
I assume this just a gaming pc ?
Cheaper option if you don't mind a few changes.
Swapped out the cooler for a cheaper air cooler. Still has a bit of white going on. It won't clash with the tall ram either so that will still be on view.
A single 2TB SSD instead of 2 x 1TB ones. Also added an extra 2TB Hard drive but you can remove it if you don't need it.
The newly released RX 5600 XT is a bit faster than the 1660 Super. If you are wanting an Nvidia gpu then you could fit an RTX 2060 Super in there.
Cheaper power supply which is still a solid unit. Non modular but not really an issue if ocuk are building it. The case has a psu cover so the extra cables can be hidden under there.
Swapped out the board for the B450 Gaming Pro Carbon as that has a couple of 5V RGB headers. I would check with customer service though just to make sure as RGB isn't my strong point.
You don't need the extra thermal paste.
As for W10 you could probably get that cheaper, but depends if you want to install it yourself or have ocuk do it.
Total: £1,295.95 (includes shipping: £14.10)
Hi
Thanks for this list. The mobo looks a good option with the built in wifi. I shall ask CS about the RGB thing. I'm not in too much of a hurry, so I'll wait a bit to see when the 5600 XT BIOS updates settles down.
I will explore air coolers a bit more as I don't know too much about them.
