I'd had a microsoft 600 for a good 6 years and i loved it so much that I bought another, but I sort of regretted it. So many manufacturers seem to do this. Slightly change the design or quality of the components used and ruin a good product. The new one feels like it is made from cheaper plastics, the keys you don't even touch can sometimes rattle - even when not pressing them despite being on a very solid desk. Some of the keys stick down occasionally too. Just doesn't have the same quality feel as the old one.
I ended up sticking with my old one as it still worked, but just had started to go a pit yellow and has some signs of damage appearance wise. I then found a keyboard by Fujitsu (the KB521). This felt really nice and was very quiet like the Microsoft one, but in time, the keys that were regularly used started sounding a lot more loose and began to rattle when other keys were pressed. The same as the new Microsoft 600 did. This was in only about 1 years use. There were also several keys that had started to stick when they got pushed down at some angles. The keys that I'd never used (the right number pad) all felt nice and like a different keyboard to the used keys. It didn't get my hopes up for this keybaord lasting if I bought it again. It was 3 times the price of the 600.
The reason I prefer white keyboards is because dust isn't visible on them which is certainly nice!
I'm also not a touch typist and sometimes do need to look at what i am typing. I often am in a dark room so a white keyboard is much nicer.
I've found quite a few budget brands that do white keybaords but don't have any media keys such as volume / play / pause / calculater and the like. I have found one other (not including the two I've owned) which is the Cherry Stream 3.0. However, there is one thing that sticks out on this. Why does it have such a tiny space bar. Haven't seen a keyboard that looks normal everywhere else, but has a significantly shortened space bar and enlarged keys either side of it on the bottom row. Really odd choice and enough to put me off.
There seems to be a much bigger variety when you look at wireless keyboards - even by well known brands that suits my needs, other than I don't want wireless. The keyboard that comes in the Logitech MK295 bundle looks really nice, but they don't seem to make a wired equivalent.
I've probably looked at most of the options there are, but would appropriate some suggestions if anyone knows of any.
A pretty quiet keyboard would be preferable as possible as my 600 is certainly very quiet. What I want really is just this keyboard again - but the old version as it was a lot better than what they now make.
Thanks.
Thanks.
soz.. no go on that front. If i were going white i'd probably just be looking at mechnical with quiet switches.
