Hi guys,
I fitted my new r290 the other night and ever since my logitec z506 speakers, specifically the speaker with the power button and volume control, has been emitting what can only be described as "white noise"
My razer mouse runs past the speaker in question and you can almost hear the movement of the mouse, amplified through the speaker? It's like a pulsing sound.
I checked all my cables and there didn't seem to be any loose connections there so tonight I pulled my sound card, a 5.1 pcie asus dg and reverted to onboad audio and hey presto, problem solved. I suspect my new graphics card might be interfering with my sound card because the pcie slot and card sit directly above it... its weird though, my last graphics card was in the same position and I didn't notice the problem then
I've just ordered the pci version of the card and I'm going to see how I get on with that. It's a strange one though, don't you think?
