OcUK Staff
- 26 Nov 2014
- Stoke
SURPRISE!
That's right, SuperFlower have 3 new units in the Leadex range in white, namely the Gold 550W, and the Platinum 550W/750W. We have had several requests to offer a white based PSU at lower wattages, and we have duly delivered. The Leadex based SuperFlower power supplies are the premium range of units from SuperFlower, and have won a huge amount of awards and accolades for their features, performance and reliability. Stock is available now!
SuperFlower Leadex GOLD 550W Fully Modular '80 Plus Gold' Power Supply - White @ £72.95 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 13.5cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 87%, 90%, 87% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
- Small Size PC Case Friendly (165mm length PSU chassis)
Specification
- Type: ATX
- Maximum Power: 550W
- Fans: 1 x 13.5cm Two Ball Bearing Fan (automatic control, semi-passive)
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage: Full Range - 100V~240V
- Input Frequency Range: 50 ± 3 Hz / 60 ± 3 Hz
- Protection: OVP/OCP/OPP/SCP/UVP
- Dimensions: 165mm(L) x 150mm(W) x 86mm(H)
Connectors
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 3x 6+2-Pin-PCIe
- 7x SATA
- 4x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £72.95 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 550W Fully Modular "80 Plus Platinum" Power Supply - White @ £82.99 inc VAT
Superflower, one of the worlds leading power supply manufacturers have unleashed a full Leadex Platinum range, all with 80 Plus Platinum Certification, offering up to 92% efficiency with class leading features, as well as offering capacities from 550W - 2000W.
All Leadex Platinum Power Supplies feature a fully modular design, 135mm silent DBB PWM Fan, full Japanese 105°C capacitors, ECO Intelligent Thermal control system, a huge amount of connectors and single rail design.
The Leadex Platinum series are a brilliant choice for anyone who wants great performance and efficiency in their system, along with the flexibility of various wattages to suit everyones needs.
Features
- 80 PLUS ® Platinum Certified, 90% 92% 89% Efficiency At 20% 50% 100% Rated Load
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection / Over Temperature Protection
Specifications
- Dimensions: 150 x 86 x 165 mm (W x H x D)
- Wattage: 550W
- Fan: 135 mm DBB(automatic control, semi-passive)
- Colour: Black (power supply, fan)
- Fully Modular Design
- Efficiency: max. 92% (115V), 80 Plus Platinum certificate
- Active PFC
- Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
- Partcode: SF-550F14MP black (UK)
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 3 x 6+2-Pin-PCIe
- 7 x SATA
- 4 x 4-Pin-Molex
- Warranty: 5yr
Only £82.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 750W Fully Modular "80 Plus Platinum" Power Supply - White @ £112.99 inc VAT
Features
Specifications
- Wattage: 750W
- Active PFC
- Partcode: SF-750F14MP Black
Connectors
- 2 x 4+4-Pin ATX12V/EPS12V
- 4 x 6+2-Pin-PCIe
- 10 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
Only £112.99 inc VAT.
ORDER NOW
Features
Specification
- Type: ATX
- PFC: Active
- +12V Rails: 1
Connectors
- 3x 6+2-Pin-PCIe
- 7x SATA
- 4x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Features
Specifications
- Wattage: 550W
- Active PFC
Connectors
- 3 x 6+2-Pin-PCIe
- 7 x SATA
- 4 x 4-Pin-Molex
- Warranty: 5yr
ORDER NOW
Features
Specifications
- Wattage: 750W
- Active PFC
Connectors
- 4 x 6+2-Pin-PCIe
- 10 x SATA
- 5 x 4-Pin-Molex
- Warranty: 5yr
ORDER NOW
