White PSU cables for new build.
29 Sep 2006
West Yorks
Recently bought new components for a build. With them being white a friend suggested getting a new white case and doing a fully white build.
So here I am, I ordered the Havn HS 420 vgpu white Wednesday, so should arrive tomorrow.
I also ordered some white Lian-li 140mm wireless fans.
My PSU is black along with the cables, so for an all white clean look, I need white PSU cables. I'm not sure what is safe and what isn't TBH. My PSU is a NZXT C1200.
My gfx card is a Sapphire 9070XT with the 2 x 8 pin power connectors.
I've seen Cablemod and Asiahorse to name a few.
What is proven to be good quality with no issues and looks the part too?
I'm not aware of any widespread cable issues with popular brands, so I wouldn't expect a problem if you stick to those. It was just the 16-pin cables/adapters that were burning.
Cable extensions are the way to go, and cheap ones at that. Once your north of £30 your basically in big chunk off a new PSU pricing.
A Cablemod full cable kit for the NZXT C series costs almost as much as replacing the PSU with a new white £150 unit and has to be made to order.
A Cablemod extension kit is £50. That is pretty big chunk off of a new PSU price and feels poor value when some full Cablemod classic kits such as a white RT series for Seasonic costs £58.23 shipped from the company direct and the Pro kit is £70.
Though bear in mind the 12vPWHR kits are more expensive, with full kits at £99 yet seem to have less PCIe cables and from memory need another 8 pin motherboard cable often ending up around £130 or so if you want a full range of cables for any eventuality.
Sadly I absolutely HATE the cables that come with NZXT more than I hate the Seasonic cables, one of the builds here has an NZXT C series black PSU, it was transferred into a white NZXT H6 build, and we just used Kolink white/black cable extensions which were as good as Phanteks extensions in one of the other builds, I would avoid Thermaltake £35 extensions due to how stiff they are these are, ended up removing them.
Instead of going with the Cablemod full kits on some of the builds here, I went with extensions, and am considering going with a back connect build in future, the H6 and H9 flow cases make the motherboard 24pin cables far more prominent than I like.
