White PSU for 4090?
5 Jun 2007
extremes.spacious.indelible
Hey all!
Going to be picking up a 4090 soon and would love a white PSU to go with a white build.
Even though the PSU won't be on show, i'd love for it to come with white cabling to match the build.
Have had my eye on the Phanteks here: https://www.overclockers.co.uk/phanteks-amp-1000w-v2-80plus-gold-power-supply-white-ca-0c6-pt.html
But seems to be out of stock and OcUK say they don't have an ETA.
Is there any other white PSU's that support the 4090 and it's 12VHPWR cable?
If there really isn't anything then if I could get a spec for a black PSU with a white set of cables with the 12VHPWR adapters?
Cheers guys :D
Cooler Master MWE Gold V2 1250W PCIE 5.0 Fully Modular 80+ Gold White​
1200w psu can also deliver the full 600w the 4090 can demand .
Thanks mate!
Why do manufacturers do white cable braids but then put black plugs on the end?! :o
Think this will have to be the one if Phanteks can't give me an ETA on when they'll be in stock on the UK :(
Thanks mate!
Your welcome.
Just to add the cooler master has a bigger fan and is longer so make sure you have clearance.
There is a 1050w version but I recommend the 1250w for the reason above.
Enjoy.
