white screen on blackberry curve 8520
16 May 2011
England
I recently broke my screen on my phone and order a replacement screen. I took the phone apart and inserted the new screen. For some reason the screen is only displaying a white screen. I've connected everything back how it was before so i haven't done anything wrong there. It could possibly be a faulty screen.
anyone had a similar problem that could help.
Thanks
A white screen on any LCD usually means something isn't connected or isn't connected correctly i.e a 5v or 12v pin signal missing from the LVDS cable.
is it the correct version. on the back of your lcd there should be some number e.g xxxx/004
you need the correct version. if you can see the number there should be some balck tape around the edges of the lcd on the back. the number should be under the tape
