White stereo with optical in for £500 or less
22 Aug 2005
Clydebank
Hi all
Looking to get a stereo setup for the other halfs front room. So used for Smart TV and music source will be TV and other things plug into that, i.e. apple tv, nintendo etc.
Criteria must have:
1. optical in required
2. must be white
Nice to have:
1. bluetooth pairing with phone
2. plain rca analaogue in
Will consider amp + speakers but only if amp is white. Otherwise, looking at active white speakers (lower box count is better), but really not sure what ones are considered good, the KEFs at £2000 look nice but don't want to spend more than £500
If standmount speakers will also need (white) stands.
Any suggestions ? Thanks
Audio Engine HD6 can be had £500 if you search.
Kanto YU6 are cheaper at £350
Both are have all of the features you specified and are both very well reviewed.
I would've also suggested the Roth VA4, as I have these and I'm very happy with them. But they are only white at the front when you remove the speaker grille.
Ii was going to suggest the Sonos beam , but it doesn't offer Bluetooth or RCA.
It works a lot better with Apple devices tho.
