White White PSU Recommendation
Ok well white atx PSU will fit my fractal north case.
Did not want to get white extension cables as it's cramped with an atx PSU cable wise.
But want white one with enough power for 5800x3d and a 3800 ti
Overclockers don't sell any white SFX PSU's. They're rare in black, not sure you'll even find a white one.
They do an SFX-L and there is an SFX on preorder
My basket at OcUK:
Total: £537.92 (includes delivery: £7.99)​
My basket at OcUK:
Hmm, I looked at SFX PSU's specifically. https://www.overclockers.co.uk/pc-components/pc-power-supplies/small-form-factor-power-supplies which doesn't actually list those. Poor show OCUK! I stand corrected.
Hmm only the Asus rog is in stock for £259 seems a bit too high just change the colour to white.
Does anyone have one of these, are they quiet?
I have a black Corsair RM850i which I never hear
£259 is too much and finding a decent white psu in stock is nigh on impossible atm.
I toyed with the idea of getting a black SFX psu to give more room underneath for white extension cables.
But as my PSU is pretty good I think ill get the white mod cable replacement, unless someone persuades me not to :)
p.s how do you link baskets?
Yep the Rog SFX-L is a pretty huge premium versus an ATX white ROG.
Not sure on the dimensions of your current Corsair (or the white one below), but the Seasonic Focus GX-850 looks a bit smaller - 150 x 86 x 140 mm (W x H x D) - it's probably a better way of spending your money (rather than spending £90 on white cables) - then resell your other PSU.
My basket at OcUK:
Total: £477.88 (includes delivery: £8.00)​
From the cart page. there is a "Share cart as" option at the bottom - if you click the BBCode option and copy and paste that into a forum post
Ended up getting the white cable mod off OCUK, instead of a new white PSU
Can't really really see my PSU through the panel at the bottom of my Fractal North case anyway.
