I got a 09 1.4 TDCI Ford Fusion with 10 fault codes. I cleared the codes and these came straight back.
B1001
Headlamp Leveling Relay Coil Short to Battery
B1002
Headlamp Leveling Relay Coil Failure
B1003
Mode Door Circuit Failure
B1004
Glow Plug Short to Battery or Transistor failure
B1005
Fuel Pump Short to Battery or Transistor Failure
B1006
Low Fuel Level to Start Heater
B1007
Coolant Pump Short to Battery or Transistor Failure
B1008
Blower Fan Short to Battery or Transistor Failure
B1009
Heat Switch Short to Ground
B100A
Smart Unlock Plausibility Fault
The only problems I have noticed is when idle the revs sometimes drop from the normal 900rpm down to 800 then back up repeatedly, I have to rev the engine to get it to stop and about 2-3 times a week it will not start after turning over a couple of times in the morning, It takes a little extra to get it to fire.
Anyone have any idea what this could be? I tried searching for answers online but could only find what the errors mean and not what causes them.
B1001
B1002
B1003
B1004
B1005
B1006
B1007
B1008
B1009
B100A
