Who is using vLite?
Yes, im using it with Vista Ultimate SP1 32bit. Never had a single problem.
EDIT: Don't blame me if something DOES go wrong though, :p.
tried to vLite onto a 4GB iRAM, unfortunatly, although we got it down to under 4GB Vista still thought it needed however much space it normally needs to install and wouldnt work :mad:
Just my 2 cents on the matter
Isn't there an option in vLite to remove the required space warning?
pagefile?
it's more stable than nlite, as all the experimental ones are hidden by default
