Who strips their GPU to clean it?
9 Dec 2009
Bristol
Built a machine from old 775 parts to keep at the GFs house during the winter and noticed it was in need of a de-fluff so stripped it down and cleaned the components.
The GPU is a Radeon X1950 pro fitted with an after market Arctic Accelero cooler. For the first time since fitting this cooler many years ago I decided to strip the GPU and give it a good clean for good measure. The inlet behind the fan was literally matted with fluff and I realised whenever I give my main machine a good clean out every 6mths or so I do everythging except the GPU. I give the fan blades on the cooler a good clean but don't actually take the thing apart.
My trusty 6950 is getting on a bit and although it has never been opened up I've got no bones about any warranty issues this late in the day so will be giving it a good clean sometime this weekend, will also replace the TIM on the processor, but I was just wondering what other people do around cleaning the GPU?
Obviously the nutters who pump liquid around their systems probably take apart every nut and bolt of their GPU anyway (so they can squirt water through it :D ) but I was just wondering what the habits are of the people who run on air.
I strip down everything (to the point of leaving the case bare bones) every Christmas holiday.
The GPU is also stripped from its shroud, fan, heatsink, everything.
If I'm feeling particulary nuts I even run compressed water through the bare heatsink (no fans or anything). Although that hasn't been needed since the 8800GT days (that thing was a PAIN to clean with the closed cell fins :eek: )
Rarely, only if theres obvious overheating. Even buy gpus with 'non reference' coolers now to keep warranty intact, used to change them but coolers on some cards are finally decent enough now not to bother.
