Who uses their laptop as a HTPC ?
6 Aug 2004
Essex
How do you do it ?
Do you buy a USB tv tuner then buy a remote control ?
If you could explain what you have done (i know some people here do it) that would be great. I might have a spare laptop that ideally could be a HTPC for me. Even if i did only play some dvd's/divx on it.
I use my laptop as an HTPC, but I use a client/server model. The laptop, like many of my other machines, is used for viewing while an old desktop equipped with a TV tuner card and a bunch of hard disks lives in the cellar. I stream everything over the network. I think it's rather cool. :)
i sometimes use mine as a HTPC with a hauppauge USB TV tuner and remote that come with it. altho no DVI means max resolution of 1024x768. its great for playing DivX movies.
