Whole System Crashing
26 Aug 2012
North West
I recently put together a new Rig and it has worked fine for over a week.
Now suddenly, I am getting random crashes whether at load or not, even in BIOS.
Any advice on what I can do to check where a fault may be?
Specs:
  • NZXT H510 Elite
  • Corsair MP600 Drive
  • AMD 3900XT
  • Gigabyte AMD 5700XT OC Edition
  • Aorus X570 Pro
  • Corsair RM850X.
  • Kraken X63 CPU Cooler with 2 Fans
  • 1 x 140mm Exhaust Fan
  • 1 x 120mm Exhaust Fan
I've checked that all Power Cables are snug still. CPU and GPU temps seem fine.
All Fan,RGB Pumps will keep running when crashed etc.
And it crashed again. Turning GPU overclock off to see if that makes a difference (no change since it's been running in the last week). Any ideas on how to isolate what could be causing the issue?
You could try setting Windows power management to max.
Disable sleep options in power management
Did you update anything before this started to happen ?
