Whoops! Forgot I had ordered that!
13 Jan 2004
Inverness
Hahaha, nice surprise when I just checked my e-mail this morning.
I've received a dispatch confirmation from the nicest competitor advising that my Xbox 360 VGA Cable has just been sent out! I had completely forgotten I had even ordered one.
Ah well, nice surprise to start the day!
I actually did the same thing. Then I got surprised when it arrived yesterday, was wondering what it was until I clicked on :o
gram333 said:
whats better to output with RGB or VGA?
Hi Def Sammy with both inputs...
Assuming you mean RGB Scart, then VGA is better.
If you have component connections on your TV as well, that will give very similar IQ to VGA.
If you mean RGB scart against VGA, then VGA wins hands down no contest. RGB scart does not carry a hi-def signal (although it is still considerably better than composite / s-video).
EDIT: beaten to it ;)
Ok im not great with connections and stuff
but by RGB i meant the Component HD AV Cable you get with premiums... the red, green and blue connectors....
is it worth me getting a vga cable instead?
