too early to tell, isn't it? Do we even know the 9800GTX specs?
We know its G92 with a 256bit interface I think, apparently its an overclocked 8800GTS 512.
Open your mind...
I doubt NV will be that stupid tbh...
ok it may not be big for us...
but it needs to be be big enough for their costing.
If it's like the jump from the 7000 series to the 8000 series then yes, if it's an overclocked 8800, then no.
.Ok you'd think NV would have done something different with the 9600GT all that is is a cut down 8800GT... Was an 8600GT a cut down 7800GT? no...
It should be a new card, should have more SP's, newer arc, not G92.. It all points to it being an overclocked 8800GTS 512, as what a 9800GX2? Its 2x 8800GTS 512..
What are you using to make this conclusion?What points to it being an overclocked 8800GTS 512mb?What are you using to make this conclusion?
No I will not be upgrading because no games require more than my 8800GT, I don't really need any more FPS I'm at 60 nearly all the time bar Crysis and I'm at 1920x1080, fantastic card.
Will probably keep this until 2009, we'll have 2x9800GX2's on one PCB before a REAL new card from nVidia.![]()
Well I don't see how an "overclocked 8800GTS" will compete with ATI's new lineup then as their single 4870 is supposed to do over 1 teraflop and the 4870x2 is supposed to do twice that.
TBH I think the 9800GTX will just be your run of the mill 65nm g92 architecture but will most definitely have more shaders. 192? 256 shaders?![]()
