Exactly, it was gonna cost a bomb to replace with Mazda OEM, so why bother? Might as well have something nice and newI plan on getting coilovers for my vRS, not so much to 'slam' it or make it handle on rails, just because replacing with new stock stuff is £600+!
Koni replacement dampers are often 90% of the maximum potential of coilovers but straight out of the box.
Well, new coilovers being fitted next Thursday, lets see how they go... I personally think this RX8 is a little sloppy than I'd have liked, and plus with a bust spring now and a leaky damper, time to replace them all! Went with BC racing BC BR series: Won't be dropping it much at all really, maybe an inch tops, but will be setting for a stiffer ride, not too much as I want the road ride to be decent, but certainly stiffer than at the moment
I went Spax adjustables on my Pug 205 with a 50mm drop, think it was one spline on the torsion bar if memory serves... Piccy of your Pug pleaseFor fast road, can't go wrong with Bilstein Sport dampers, slightly stiffer springs and OEM replacement bushes.
That's what I'm going to use on my 205 GTI.
Thing is you would be as well doing the springs too. and that puts you from 300-400 quid to 500-600 quid which is the same as coilovers:/
