Hi all,
Got a slight problem with my WHS2011 install in that it won't keep time properly after a reboot. I can sync the clock with time.windows.com and it will display the correct date and time but the next time I reboot it will then revert to being 8 hours ahead.
The timezone does not change (i.e. when it says its 8 hours ahead its still using the london/dublin timezone.)
Anyone have anything similar to this/know how to fix it?
cheers
EDIT: its running under ESXi 5.1.0
cheers
