So yeah, looks like there will be a 'home server' just in the form of windows 2012 server essentials
There is no new home server, essentials is for small businesses.
yes and also 'home' use even if not strictly WHS, as it has DHCP etc and all that.
Im still on WHSv1. WHS2011 was a step back, and Server 8 Essentials looks like an even bigger step back and considerably more expensive. I think my original WHS cost me £80 or something?
Drive Extender with a console front end, the frankly epic backup tool, and the ability to still have a full on Server 2003 system running underneath is just brilliant.
The only thing it doesn't do is Remote Apps, but thats not a big enough issue for me to want to move to 2011 or 8. I can see me using v1 for a considerable time yet.
Im still on WHSv1...
WHS2011 isn't all bad as at the very least it gives compatibility with 4K advanced format drives, which can be problematic on WHSv1.
Also depends on the size of your shares, but unless a share is bigger than an individual drive it's probably not so much of an issue.
The advanced format drive issue is easily fixed (on WD drives at least) with a jumper.
And I have shares well on the way to being larger than the 1TB drives I have.
Basically WHSv1 offers me (almost) everything I need. I think the biggest issue with any future home server will be the cost though. Isn't W8 Server Essentials going to be about £400?
Stay on WHS2011. Other than Storage Spaces, which I won't trust my data to, WSE2012 offers little new - and in some respects less...e.g. won't allow you to install other roles such as WSUS which WHS2011 allows.
Even with the jumpers or supposed native backward compatibility I still saw problems with most of these drives. Basically a lot lower level of performance, coupled with the constantly running demigrator.exe, meant I'd often see stutters with streaming full fat HD content.
But I agree WHS 1 was a good product ahead of it's time.
With the death of DE I just decided to go for a proper hardware RAID. Expensive yes, and I've never looked back.
WSE2012 is shown on the MS site as $425. Many will find that expensive but It'll be down to the individual as to whether that's worth it or not. There's always Amahi if they don't like it.
