whs and scanners?
7 Mar 2005
Does anyone know of any scanners or 3 in 1 printers that are compatible with whs? I have heard of the printer working fine but the scanner not being recognized?
Any advice appreciated thanks :D
i'm using an epson rx560 with no problems, it's a bit old now but still works perfect so if this old thing does the the newer epsons should be fine as well :)
As long as it has Server drivers it should be fine.
It will only work if you scan through WHS though. Obviously you cannot scan over the network.
Or get an printer like my new Epson PX700w, it is wireless, and RJ45. And has the scanners drivers loaded on each client, so you dont need a central server. And it can scan, and print all via any client PC.
