- 23 Jan 2007
- Wakefield
To be honest I'm just thinking out loud and there won't be answer to this.
I currently have a 4670k running at 4.4ghz with voltage at 1.275v
I have 2 x 780ti's at 1124 with a max voltage of 1.2v
EK supremecy evo, 2 x EK 780ti full blocks, 2 x D5 pumps, 1 x Havoc 480, 1 x Havoc 240 and an Alphacool 280 XT45. On the 480 I have 4 x Corsair sp120's + 3 x Artic f12's p/p, on the 240 2 x Phantek 140's and 2 x Arctic f12's p/p, on the 280 there's 2 x Noctua A14's and 2 x Phantek 140's p/p, all housed in a Phanteks Enthoo Primo V2. Air is coming in from the front and bottom of the case and exhausted out the back and top. (I've tried the 480 sucking air in with no differerence).
So what's the problem?
The water temp seems to be quite a bit higher than I expected, I know it'll be fine and nothing to worry about, but it seems high and everything feels very warm. While playing something that uses both cards like Shadow of Mordor the water temp can hit 43c. The video cards are generally 2-3 degrees higher than the water and the cpu hovers around 50-60c. But if I run something like IBT the cpu spikes to 80c but hovers in the 70's. So I know the equioment temps are okay, but the water should surely be lower with all that rad space?
The fans run at around 800rpm when gaming which is a nice volume, 1,000rpm if I have to and last night I tried full speed at around 1,500rpm which dropped the water temp to 38c, but the room temp was also dropping as it was getting late. I have a little thermometer in the room and that was reading 26c air temp when it was 43c water. I've tried the D5's at full speed and it gets noisier but no cooler. Due to a leak with a fitting that has been exchanged twice the system has been drained and filled about 5 times over the last couple of weeks, so I dont think it's an airlock. It takes about 1 3/4 litres to fill which is about right for the size.
I've thought of changing the fans but I'm not sure if that's a solution. It appears I have a very hot running cpu even after remounting it a few times and even with the new tube of IC diamond making no difference. I know the gpu's put out a lot of heat but with a 1,000mm of rad space surey the water would be lower.
It's just the fact I've seem people with less rads and similar equipment with much lower temps, I know you can't compare but I feel like I've done something fundamentally wrong even though I can't see it. Unless of course I've got a faulty water temp sensor that just reads very high.
Thoughts?
Thoughts?
