There is one thing that I have noticed, not just now, but for quite some time now, and that is that a lot of the good Motherboards, are seriously awfully laid out!
I will give you a couple of examples of a few of mine...
1 - MSI Neo2
Now, those of you who have one, will agree with me on this, but the ATX, IDE Ports and the FLoppy port are all crammed into the same spot.
Now, this does not pose too much of a problem as such, but when I got my Neo2, I bouht an Ultra-X Connect PSU and an Arctic freezer 64 and guess what happens if oyu mix that lot? The Thick bulky PSU cables push into the flopp & IDE Cables which in turn, wedges into the FAN on the Freezer - result was that the fan did not spin up properly?
2 - Gigabyte DS3
Now, come on.. a Good clocker and one of the most useless NB coolers in existence. Even the whoel issue of fitting one is an awkward one with so many people killing their Motherboards due to somehting touching here or there, and to be fair, there is something abotu LGA775 coolers that really makes me a little worried especially the way they attempt to hang onto the motherboard as if they are about to fall off all the time...
3 - This is a recent one, and it rings true for a lot of SLI boards that I have seen... The 2xGFX Ports are miles apart, with 2xPCI slots between them, and the bottom GFX slot has a PCI slot right under it... Now, I am trying to use 2x6600GTs in mine, both are cooler with Artic coolers and guess what? Because of that I can only actually use one PCI slot... The very bottom one!
If I put the stock cooler back on, I can use 2, but then I intend on clocking them soon and so I dont want to risk that.
4 - MSI Neo4-f ( This is also true for a hell of a lot of Mobos actually )
Where is the NorthBridge cooler? - Right under where the Graphics cards go! - rendering any chance of using anythign other than the stock ( look under "crap" in the dictionary ) cooler, totally obsolete.
5 - SATA Connections.
Why is it, that on any of my motherboards that do have more than one SATA controler, that the best ports ( The non-clocking ones ) are always chucked up right next to the CPU socket and the ones in a nice position are the ones that get clocked up if you try upping the FSB ( MSI Neo2 and DFI LP250UT are both like this )
Has anyone else noticed these kinds of issues?
1 - MSI Neo2
2 - Gigabyte DS3
