Why are my SPI times so CARP?
18 Feb 2009
Essex
Hello there,
I'm at 4.4 (1.33v) with 8GB @ 1866 9-10-9-27 (1.5v)
I tried running a 1M test and the time was at 20 seconds by loop 3 Lol
I'm assuming my overclock is either as stable as Britney Spears or about as efficient as a V8
Thoughts please?
Are you using the power saving features??? If so SPI may not be clocking up the CPU to full speed. Its only single threaded. Try changing power plan in wondows and run again. Also try CPU-Z to make sure your OC is being applied correctly.
CPUz reports the full 4.4 (x44) All c states are disabled, I have speedstep and turbo enabled. Also, none of the benchmarking options are enabled in BIOS (M5F). My windows power plan was set to "balanced", but I've just set it to "performance"
I shall report back
Just tried again. The initial value takes a smidge under 5 secs, the whole 1M run took a fraction over 1m 8 secs. I have nothing running in the background apart from my security software (other than essential windows services, natch)
Is it anything to do with vcore, could mine still be too low? I primed (blend) with the same settings at x45 last night and it fell over after about an hour, so I dialed it down to x44
I'm only getting about 60+ Gflops in IBT, each run takes around 245.xxx. My scores were much higher and took less time with an i7 920, and that was at a lower clock Lol
Is the CPU throttling?? Open CPU-Z when doing a run and check the frequencys. What board are you using???
Yes it is. The multi does nothing but fluctuate between 16, 29, 44, 20, 17, 26, 44, 16, 31 etc etc for the duration of the run. Mobo is Maximus 5 Formula, CPU is a 3570k, RAM is 2x4GB Dominator GT 1866
It shouldn't be, have you monitored cpu temps, vrm cooling(ought to be fine on that type of board). You have some troubleshooting to isolate the cause im afraid but it does sound like your oc is unstable, casuing throttling.
You mentioned it failed prime, does it still on a lower multi? What about on small fft?
You need to check CPU temps under load first for this one. Use Cpre Temp or Real; temp and run some load see the temps. You may have a bad cooler mount so this may need redoing also check the Vcore your at.
