Why are the core speed and boost clock of 1050 higher than the 1050 Ti one?
The 1050ti has a larger number of cores - around 20% more cores and only around 4% lower on paper clock (in reality it will likely boost to around the same numbers as a 1050 anyhow as the on paper boost clock is just the "guaranteed" lowest sustained boost). The end result is that it will run 15% or so faster - I've not checked the benchmarks.
