Why are you not selling Auzentech anymore?
They've disappeared of the face of the earth, no there appears to have been some sort of disagreement with the distributor who no longer distributes them.
(I was looking for drivers) apart from that I've no idea.
Happy New Year
It'll probably be down to them being so overpriced people stopped buying them.
X-Mystique at £35 original price = bargain
X-Mystique at £70+ = Having a laugh
would get the x-fi fatal1ly gamer without front panel ,only got music version few months ago and didnt work with old system which was abit av83eye mobo,system wouldnt boot,so put in audigy4 card and worked good,was looking to see if anything better than audigy4 there
check few reviews
the new card is better and some have used on vista
just heavy price
might think about getting ,otherwise get the x-fi fatal1y gamer card without front panel
Yeah, I got mine at that; they just don't cut it for analogue though which i'm now using more than digital. No way would I ever have spent £75 on one though.
I'll probably sell it and get an M-Audio 2496 when the MM is back up and running.
I read these cards do NOT supports OpenAL which will eventually replace EAX in games.
I have also read the Xtreme Gamer ( small PCB ) does not use software acceleration, but the Xtreme Audio DOES use software.
The difference between the Gamer and Xtreme Music is just shrunk PCB and less outputs. Is this correct?
BTW I am NOT talking about *** fatality version..
KELTICKNIGHT said:
will see,might get the fatal1y version without front panel,other wise will wait for new sound cards that will appear for vista
Doubt you'll see any new soundcards released because of Vista.
first off phil
happy new year
at moment looking at 2 x-fi
can get fatal1y version for 30 euros more than music version
with bad experience with olsder music x-fi not allowing my older system to boot,being careful
