Warspite said:RAW is not intended to be edited, the idea is you save it as either JPEG, or but better still as a TIFF file, then edit that.
konicky said:Of course you can edit RAW, that's kinda the point of shooting RAW! Take RAW image, make all the adjustments required then save as jpeg![]()
Tonks said:Warspite, old Q2ctf HSF Warspite?
Off topic sorry...
rG-tom said:if its like the 20D, to see raw you have to put the communication on PTP in the menu to see raws through explorer
Hope that helps
Tom.
