Hi guys,
I'm aware of what the "pathping" command should allow me to do and I know, in the past I've been able to run it without an issue. However I cannot remember what router I was using, what OS I was using when it did all "just work".
So I'm using Win10 and I'm using a BT HH3. Command prompt opened with "administrator" privileges.
If I used the command: pathping -n xxx.xxx.xxx.xxx (any IP address you like) I get the following:
C:\>pathping -n 134.170.185.46
Tracing route to 134.170.185.46 over a maximum of 30 hops
0 192.168.1.82
1 192.168.1.254
2 * * *
Computing statistics for 25 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0 192.168.1.82
0/ 100 = 0% |
1 0ms 0/ 100 = 0% 0/ 100 = 0% 192.168.1.254
Trace complete.
So in other words we have hop 0 which is my PC, we have hop 1 which is the router (BT HH3) and that is it. It always fails to get a hop 2 (as above) and then just processes the results to the HH (not much use when I'm trying to find an issue on a path elsewhere).
I'm on BT Infinity 2 as my ISP.
Any idea what is going on?
The abvoe happens no matter what IP address I try to get through to, so something BT are stopping me from doing?
Ta
0 192.168.1.82
1 192.168.1.254
2 * * *
0 192.168.1.82
0/ 100 = 0% |
Trace complete.
Ta
